Home > Forums > CFX
Tubrogrid - Error on cut-off at TE
Old   February 23, 2008, 10:24
Default Tubrogrid - Error on cut-off at TE
Flavio
Hi all. I generated a profile.curve file using matlab of a compressor blade, described by 12 sections. The profile chosen is NACA-65. If i use the original geometry of the naca-65, with null thickness at trailing edge, turbogrid gives no troubles and imports the geometry correctly. If i modify the naca-65 adding somewhat more thickness on TE (as it is obvious to do regarding a compressor blade profile), then, importing profile.curve in TurboGrid, i need to specify "Square or cut-off" at trailing edge. Doing this, the program returns error (it says that couldn't execute trimming at blade trail). I wonder what could be the problem but just can't find out. Thanks for helping.
Old   February 23, 2008, 10:27
Default Re: Tubrogrid - Error on cut-off at TE
Flavio
Here is the errore message produced by the TurboGrid when i specify "cut-off or square" option for trailing edge:
"Trim operation failed to produce any surfaces for surface Blade_1_ex_trail"
Old   February 26, 2008, 04:47
Nicola
Open profile.curve and write TE and TE2 next the two trailing edge points. Make it for every sections. When you import profile.curve in TG set TE cut-off! Regards
Old   February 28, 2008, 13:21
Flavio
Thanks for helping but it makes no difference.
Old   February 29, 2008, 05:10
Nicola
It's strange! Are you sure blade points are correct? How did you add the thikness? TG is very sensible and crashes if some points aren't written in series.
See this example about a cylindrical NACA 65 profile with cut off at 95 % of chord.
profile.curve in mm
# Section Hub
95 0.308 200 TE
90 0.812 200
85 1.387 200
80 1.989 200
75 2.586 200
70 3.158 200
65 3.684 200
60 4.148 200
55 4.532 200
50 4.814 200
45 4.965 200
40 4.998 200
35 4.926 200
30 4.762 200
25 4.505 200
20 4.145 200
15 3.668 200
10 3.042 200
7.5 2.649 200
5 2.179 200
2.5 1.576 200
1.25 1.171 200
0.75 0.934 200
0.5 0.774 200
0 0.000 200 LE
0.5 -0.77 200
0.75 -0.93 200
1.25 -1.167 200
2.5 -1.572 200
5 -2.175 200
7.5 -2.645 200
10 -3.038 200
15 -3.664 200
20 -4.141 200
25 -4.501 200
30 -4.758 200
35 -4.922 200
40 -4.994 200
45 -4.961 200
50 -4.81 200
55 -4.528 200
60 -4.144 200
65 -3.68 200
70 -3.154 200
75 -2.582 200
80 -1.985 200
85 -1.383 200
90 -0.808 200
95 -0.304 200 TE2
# Section Shroud
95 0.308 500 TE
90 0.812 500
85 1.387 500
80 1.989 500
75 2.586 500
70 3.158 500
65 3.684 500
60 4.148 500
55 4.532 500
50 4.814 500
45 4.965 500
40 4.998 500
35 4.926 500
30 4.762 500
25 4.505 500
20 4.145 500
15 3.668 500
10 3.042 500
7.5 2.649 500
5 2.179 500
2.5 1.576 500
1.25 1.171 500
0.75 0.934 500
0.5 0.774 500
0 0.000 500 LE
0.5 -0.77 500
0.75 -0.93 500
1.25 -1.167 500
2.5 -1.572 500
5 -2.175 500
7.5 -2.645 500
10 -3.038 500
15 -3.664 500
20 -4.141 500
25 -4.501 500
30 -4.758 500
35 -4.922 500
40 -4.994 500
45 -4.961 500
50 -4.81 500
55 -4.528 500
60 -4.144 500
65 -3.68 500
70 -3.154 500
75 -2.582 500
80 -1.985 500
85 -1.383 500
90 -0.808 500
95 -0.304 500 TE2
hub.curve
-100 0 200
200 0 200
shroud.curve
-100 0 500
200 0 500
Regards
Thread Tools
Trackbacks are On
Tutorial of how to plot residuals ! wolle1982 OpenFOAM Running, Solving & CFD 132 May 20, 2016 09:28
Plotting Residuals ata OpenFOAM 12 July 8, 2011 02:50
[ICEM] Cut existing Mesh in order to use symmetry camoesas ANSYS Meshing & Geometry 10 October 7, 2010 05:13
Boundary conditions on a wake cut sjs OpenFOAM Running, Solving & CFD 3 August 6, 2008 21:56
Graphical pressure distribution from a cut Aline CD-adapco 3 August 4, 2004 11:50
