icem hexa mesh fot turbine
Old   February 25, 2008, 03:29
Default icem hexa mesh fot turbine
zio_billy
Hi, I'm doing various tutorials to learn how to generate mesh with icem hexa. My goal is to generate a mesh for a turbine with very skew blade and complicated shape. Can someone tells me about any tutorials, article or hint about that subject? Thank you Zio
Old   February 25, 2008, 05:48
Default Re: icem hexa mesh fot turbine
Rogerio Fernandes Brito
I had been worked on a group as a reasearcher that made a simulation like that with ANSYS CFX-v11.0, using hexa meshes, but i didnīt make this kind of mesh! Itīs very difficult. You must create blocks inside of each region of the channel of stator and rotor. Around the profile, you have to create an o-grid mesh type. This kind of mesh brings better results with less computational effort.
Best Regards, Rogerio Fernandes Brito.
Old   February 25, 2008, 05:59
I had worked on a group as a researcher that made a simulation using ANSYS CFX-v11.0, using hexa meshes, but i did not make this kind of mesh! It is very difficult. You must create blocks inside of each region of the channel of stator and rotor. Around the profile, you have to create an o-grid mesh type. This kind of mesh brings better results with less computational effort. (I am sorry, my english...)
Old   February 25, 2008, 16:42
You are correct in that meshing turbomachinery in difficult. ANSYS has a product called Turbogrid which may help. It generates very nice turbomachinery meshes.
Old   February 25, 2008, 17:14
U can export the data from bladegen and make a hexa mesh for the channel stator/rotor on icem cfd using blocks! itīs not easy!
Old   February 26, 2008, 05:07
I have never used turbogrid but I understand it can generate the meshes also. No need to export to ICEM. Please correct me if I am wrong.
icem hexa mesh parts pb jaber CFX 5 July 8, 2009 03:59
icem hexa mesh parts pb jaber Main CFD Forum 2 July 7, 2009 15:30
icem hexa mesh beginner icem beginner Main CFD Forum 3 July 9, 2008 07:08
ICEM hexa mesh tutarial 2d car problem cfduser Main CFD Forum 0 March 8, 2008 16:13
How to smooth hexa mesh externally in ICEM? BONOHUGO Main CFD Forum 2 July 16, 2007 16:59
