Home > Forums > CFX
saving mid solve
Old   February 26, 2008, 08:02
Default saving mid solve
Chris Wetton
Hi, im currently running some models in cfx and want to save the results mid run. Is this possible and how can i do this. thanks Chris
Old   February 26, 2008, 08:40
Default Re: saving mid solve
andy20
Hit the disc shaped button on the toolbar of the CFX Solver monitor. Then, at the the end of the iteration, you will see a message in the text output window saying that a backup file has been written. The filename will be ##.bak, where ## represents the iteration number. It will be saved to the directory being used by the current run.
Give CFX enough time to complete the writing the file - they can of course be very big - and to release the file lock (just a few seconds to wait - but saves confusion). Then fire up CFX-Post and open the .bak and see your results.
Note that if .bak files are created, then the run directory is not deleted at the end of the run - so be careful they don't start to take up too much disc space if you do a lot of backups.
(The alternative answer would have been to RTFM! It's all explained there.
Good luck, Andy
Thread Tools
Trackbacks are On
How to solve this kind of continuity equation? shddx1 OpenFOAM Programming & Development 0 July 7, 2011 15:31
Solve Flow or VOF simultaneously ? Ramsey FLUENT 1 February 16, 2011 14:16
Linearized NS euqations: how to solve them?(problem with Matrix operations..) matteoL OpenFOAM Running, Solving & CFD 0 November 18, 2009 07:58
Solve for two or more "Temperatures" Rui CFX 12 September 9, 2008 21:58
How to solve another continuum and momentum eqn? west_wing FLUENT 0 August 25, 2003 10:00
