February 26, 2008, 03:11 |
Zero pressure gradient
Hallo, I need to implement zero pressure gradient as boundray condition. But the only BC s are opening and outlet BCs. How could I specify zero pressure gradient BC?
Thanks in advance, --Selim |
February 26, 2008, 16:59 |
Re: Zero pressure gradient
Is this an inflow or outflow condition?
At an outlet, the "Average Static Pressure" and default "Specified Mass Flow" options are both zero gradient (i.e. the local mass flow rate is allowed to float). If you expand the mass flow options, the default is "Scale Flows", which is the zero gradient option. Others include the "Scale Pressure" option, which allows you to specify the pressure profile and "Constant Flux", which (as the name suggests) pulls mass out at a constant rate. On Openings there is a zero gradient option for both momentum and turbulence, but the pressure must be specified. -CycLone |
February 27, 2008, 03:00 |
Thanks a lot,
--Selim |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 06:52 |
Inputting pressure gradient in Fluent | Josyula | FLUENT | 2 | December 23, 2009 07:26 |
Atmospheric pressure gradient | Luc3er | FLUENT | 1 | October 30, 2009 06:46 |
Hydrostatic pressure gradient | Craig Finch (Finch) | OpenFOAM Running, Solving & CFD | 10 | February 28, 2007 23:02 |
Flat plate with pressure gradient | Sheila | Main CFD Forum | 3 | September 24, 2005 13:58 |
