Home > Forums > CFX
Mesh Displacement error
Old   February 27, 2008, 00:14
Default Mesh Displacement error
mike
I am try to model an oscillating plate in a fluid flow. I get this error when solving:
A negative ELEMENT volume has been detected. This is a fatal | | error and execution will be terminated.
I've increased the mesh stiffness with respect to small volumes. What would be a good method to solve this error?
Old   February 27, 2008, 08:13
Default Re: Mesh Displacement error
Fusion
You need to better check your mesh, sometimes meshing codes create "negative" volume elements or cells with a volume smaller that some tolerance. In ICEM I found two different types of generated errors: a block-refined mesh in which some blocks have a wrong volume orientation, or a tetra mesh in which the code introduces volume errors by means of displacing nodes in smoothing operation or during a "delete last operation" process. The former type of error can be easily removed automatically using the "check mesh" procedure; while the latter needs you to manually repair your mesh if possible, if not you have to restart creating your mesh.
Thread Tools
Trackbacks are On
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
Installation of Netgen in SuSE Linux 92 edvardsenpriv Open Source Meshers: Gmsh, Netgen, CGNS, ... 23 January 16, 2009 07:12
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
