max residual I-radiation (Discrete Transfer)
Old   March 14, 2008, 06:21
Default max residual I-radiation (Discrete Transfer)
daiga
hi,
I am modelling radiation heat transfer in non-boyant fluid media (absorption coefficient 50 m^-1) using Discrete Transfer model. Fluid is in a closed volume; temperature boundary conditions on the faces (emmisivity 0.9). H-energy converges well; the problem is - I do not see I-radiation residual at all - even if I change the range to (1e-100; 1e+100). I can see only the legend of I-radiation, but there is no line in the plot. The only residual I can plot (concerning radiation HT) is I-Radiation domain source.
Where can be a problem? thank you in advance
Old   March 14, 2008, 10:54
Default Re: max residual I-radiation (Discrete Transfer)
daiga
probably, found the problem by myself - Discrete Transfer model is not appropriate for absorption coefficient 50 m^-1.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
