Y plus in fluid fluid interface
Hai All,
I am doing simulation of a cooling fan with CHT model. In my mesh, I have a y plus value less than 1 for those close to the solid boundaries. I have divided the fluid domain in varoius domains for simplicity. At the fluid fluid interface, I have y plus values greater than 1. And one of the interface close to my fan but does not toouch it. Does it really have any effect on my simulation? I guess not, since there is no solid boundary at this interface. Thank you for your replies. Regards, Subha. |
Re: Y plus in fluid fluid interface
this should be fine
Re: Y plus in fluid fluid interface *NM*
It is necessary to maintain a good values of Y plus even for Fluid Fluid interface if you want simulate accurately.
Why??? What is your logic? Checks on Y+ should be used to ensure turbulent wall functions will work accurately at no-slip walls. In addition, when using low-Reynolds number turbulence models the value of Y+ is used to ensure boundary layers at no-slip walls are resolved. You can read the theory related to this in the CFX help system. At a fluid-fluid interface there is no wall, and no boundary layer! Therefore the value of y+ is surely irrelevant. What, therefore, makes you think y+ is important at a fluid-fluid interface? |
