How to find Heat Transfer Co-efficient (HTC)?
Old   February 23, 2008, 20:42
Default How to find Heat Transfer Co-efficient (HTC)?
Raja
Dear Friends,
Could you please tell me how to get HTC (Heat Transfer Coefficient) in CFX out put results? I would like to know whether CFX can give HTC values of an object if it dissipates power in natural of forced air convection.
Thanks a lot for your time!
Old   February 24, 2008, 06:56
Default Re: How to find Heat Transfer Co-efficient (HTC)?
Thiago Queiroz
If I can remember correctly, you can't. You'd have to create a function with the definition of the HTC.
Old   February 24, 2008, 16:41
Thiago - you are incorrect. CFX has the HTC as a variable in the results file for a simulation with heat transfer.
To access it you have to click on the "..." button on CFX-Post.
Also, note the HTC is referenced to a "far" temperature. By default the far temperature is the variable (I think this is its name) "wall adjacent temperature". You can use a expert parameter to fix this far temperature to any value you like for comparison to published data.
Old   February 24, 2008, 16:52
Thiago Queiroz
Alright, sorry about that and thanks for pointing out.
Old   February 24, 2008, 19:57
Raja
Dear Thiago Queiroz and Glenn Horrocks,
Thanks a lot for your reply.
Old   March 4, 2008, 13:20
manas
hai,
how to find out the heat transfer co-efficient by natural convection equipment(fabrication method).please mail me immediately.
calculate heat transfer coefficient in repeated geometry mullenc525 CFX 4 January 24, 2017 14:30
Modelling the heat transfer during compression and cooling of natural gas pano Main CFD Forum 0 December 10, 2010 15:53
Heat Transfer in Porous Medium eryan STAR-CD 0 September 28, 2010 13:14
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
CFX Heat Transfer RJamison CFX 0 July 24, 2008 12:11
