March 6, 2008, 12:06 |
Hypersonic flow cases!!!!
Hi friends, whether cfx predicts hypersonic flow cases??
I have tried, but the results obtained were not matching with the experimental results. May be, there were some mistakes also. That is why this question I have posted. Kindly share your ideas. Thanking you. |
March 6, 2008, 17:38 |
Re: Hypersonic flow cases!!!!
CFX does not model plasma physics. If significant gas dissociation occurs CFX will not be accurate. It can model supersonic flows up to significant dissociation, however. Glenn Horrocks |
March 6, 2008, 21:19 |
Unless you type in the dissociation physics, i.e. input the and solve the chemistry as well as type in appropriate CEL for transport properties, as well as appropriately modify the wall BC..
Display Modes | |
Finite Rate Chemistry Setup for Hypersonic Flow | AdeeMij | FLUENT | 22 | July 11, 2017 11:28 |
Hypersonic flow capabilities | Gaurav | FLUENT | 3 | June 4, 2014 15:02 |
Hypersonic flow scramjet | ishaninair | OpenFOAM Running, Solving & CFD | 0 | March 10, 2011 08:45 |
Hypersonic flow ... | Johnix | FLUENT | 0 | April 24, 2002 15:08 |
Hypersonic flow applied to blunt nosed (ie. 2d bodies) | manishkumar | Main CFD Forum | 1 | January 10, 2000 23:36 |
