mesh independancy?
Old   March 13, 2008, 06:40
Default mesh independancy?
amine
i've set a mesh which converged,but when refining the convergence was achieved ,is the problem a timescale kind or acually a mesh one.
thanks
Old   March 13, 2008, 06:48
Default Re: mesh independancy?
matej
Dear amine, it is hard to understand what whould you like to know.
both cases converged, so what is the problem?
matej
Old   March 13, 2008, 07:22
Default Re: mesh independancy ?
amine
my question was, i set a mesh that converged,when refining that mesh the solution didn't converge at least after a large timestep iterations & ocilated which wasn't the case previously.
thanks
Old   March 13, 2008, 13:36
Craig Hildreth
You are probably resolving details in the flow the prior mesh could not and these disturbances are affecting convergence.
Old   March 13, 2008, 16:42
Craig is correct. Try using a larger physical timescale.
Old   March 13, 2008, 17:05
longbow
I don't see the logic behind increasing timescale whenever you see oscillation. What if that oscillation is a real physical phenomenon? Using large timescale to get rid of oscillation just for sake of getting converged result is not always a good practice.
Old   March 17, 2008, 16:41
I agree with you longbow. The full answer is work through the points on this link, of which increasing timescale is one:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
ps: I wrote this FAQ answer so I am well aware that there is more to it than just increasing the timestep!
But I am a lazy typer so couldn't be bothered writing the whole thing every time somebody asks it. This question has been asked dozens of times so it gets pretty boring.
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
