UserFortran
If I want to monitor mass flow average of temperature at outlet in a domain, then i can specify the same in CCL file which will reflect in solver as massflowAve(temperature)@outlet. This is simple as temp is a system variable.
Note:As far as I understand, USER_GET_GVAR subroutine in the junction box code does this concatenation for us. Now is it possible to monitor a user variable like coeff of lift which is a fuction of normal and tangential forces and print its value after every iteration using a junction box routine or User CEL function?? |
