March 16, 2008, 16:04 |
mesh quality ?
i've set a mesh which gave a converged solution ,now when refuning this mesh the RMS oscillated , i think that the mesh quality became bad , is it feasible to just repair the mesh, or i should which to another mesh. thanks |
March 16, 2008, 16:39 |
Re: mesh quality ?
Time spent improving mesh quality is never wasted. Glenn Horrocks |
March 16, 2008, 17:18 |
Re: mesh quality ?
then what should actually improved on the mesh ,it means which parametrers should be improved ,if the area (region ) causing the problem is known ?
March 16, 2008, 21:01 |
Re: mesh quality ?
i do not know what package you used to produce the mesh.if you are using icem, you can use the powerful mesh quality checking tool to examine the mesh and find out which part of the mesh have bad quality.
March 17, 2008, 16:34 |
Re: mesh quality ?
The main mesh quality issues are aspect ratio, orthogonality (for hex meshes, tet meshes like equilateral triangles) and a gradual change in element size. The implications of these quality issues are discussed in the documentation. Glenn Horrocks |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] trouble with mesh quality from ICEM in CFX Solver | escher25 | ANSYS Meshing & Geometry | 0 | February 28, 2011 07:38 |
[snappyHexMesh] mesh quality control and fix | tachyon_me | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2009 12:48 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
