steady state simulation timesteps
Old   March 10, 2008, 14:17
Default steady state simulation timesteps
amine
i have set 500 000 elements on my simulation,i've read on the help that the steady state simulation should converge after 50 to 100 timesteps ,now my question is ,if it exceeds 200 timesteps and it on the way should i wait more or i have to change the meshe,i'm using high resolution scheme.
Old   March 10, 2008, 14:44
Default Re: steady state simulation timesteps
Dre
What is your convergence criteria?
Old   March 10, 2008, 16:21
Kushagra
It will depend upon many factors.
1) Do you expect (with reasonable assumption) your flow to be a steady state flow? If not, then it would be very difficult to get it converged with 'high resolution' scheme. You might think about switching to transient solver. If your flow is any where near to steady state nature, your transient simulation will show it. Just monitor velocities/pressure at some points in your domain.
2) If simulation is diverging, reduce the false time step in steady state simulation. But it will slow down the simulation. Hnece the benefit of using steady state solver is lost.
3) Check out the location of high residual in CFX-Post. (You will need to enable to 'out put eq residual' in CFX-Pre -> output control-> results, set it ALL)
basically, it would depend upon nature of your flow, mesh quality, and time step...etc....
Read the documents (modeling advice )on convergence as well...
Kushagra
Old   March 17, 2008, 00:13
Default confius on operation setting
wan
For laminar i should set the [default domain modified->terbulence] to [none-laminar], but if i want to run under terbulence condition, which operation should i select [k-epsilon/shear stress transport/BSL Reynold stress/SSG reynold stress]?
Old   March 17, 2008, 10:29
Default Re: confius on operation setting
Kushagra
depends upon ur problem... zero equation model->k-e->Reynolds stress(SSG-RSM,LLR-RSM)->LES turbulence models are in the order of increasing computational cost....
for some problems k-e will work, for some even RSM might not work....
search out the papers on your problem and get an idea...read the CFX-11 manual as well
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
How to speed up the simulation of a large amount of similar steady state cases tss Main CFD Forum 4 November 5, 2010 14:36
Mass Diffusion: Transient and Steady State BC rval CFX 3 November 19, 2008 00:52
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
steady state simulation manoj FLUENT 1 March 20, 2004 07:15
