Heat transfer trough a solid domain
Old   March 17, 2008, 11:00
Default Heat transfer trough a solid domain
Tiago
Hi all.
It seems that heat flows from a wall, across the contact boundaries doesn't seems to work between deferents domains, one fluid (air) and a solid domain.
The heat doesn't seem to cross the interface contact boundaries of the solid domain.
Old   March 17, 2008, 12:04
Default Re: Heat transfer trough a solid domain
luis
Try with k-w turbulence model or SST.
Old   March 17, 2008, 14:54
Tiago
Thank you for answering.
After all it was easier than it seams. Making one sectioning view with a plan in the details of the plan, the colour tab, it must be TEMPERATURE variable and not TOTAL TEMPERATURE, as i was doing. Don't ask me why... it works.
Help needed in meshing for Solid to Fluid Heat Transfer niazaliahmed FLUENT 2 February 22, 2020 15:47
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
heat conducting in a solid domain Rogerio Fernandes Brito CFX 0 March 18, 2008 17:20
