March 18, 2008, 09:18 |
dynamic viscosity setup
I was trying to simulate a hydraulic system, however, the simulation result is always 30% higher than testing result. I'm guessing there might be something wrong with my fluid property setup.
I did simulate and test just a constant diameter tube. The results still don't match. I'm using "pure substance" option with the correct density and dynamic viscosity at the testing temperature. I left the molar mass the same as water (18.02 kg kmol^-1). Is there anything else I should do? |
March 18, 2008, 13:47 |
Re: dynamic viscosity setup
Did you run your tube as Laminar flow or turbulent?
March 19, 2008, 07:18 |
No, I have not. I probably should. However, I did run the same tube with the same physics, except with water. The results were correct even with SST turbulence model. I'm sure if it was laminar with oil, it won't have much turbulance with water.
March 19, 2008, 15:21 |
The viscosity of water is different, so your Reynolds number will be different and hence the effect of turbulence as well. If you are comparing to laminar flow data, you should turn off the turbulence model (i.e. run laminar).
-CycLone |
March 19, 2008, 17:11 |
I did run with laminar. The result was closer to reality. However, I did notice that with a inlet Mass Flow Rate setup, the flow took over 2ft to develop. The velocity profile over the 2ft long pipe was changing all the way through. That did not make sense.
Here's some detail of the setup: Volume flow rate: 12 gpm pipe id: .484 in pipe length: 2ft. I try to run it with the viscosity of Mobile dte 24 which has a dynamic viscosity of 31 centipoise @100°F Lab test showed 3.7 psi Pressure drop. CFX with laminar method has a result of 6.9 psi |
March 20, 2008, 11:01 |
Try setting the inlet as a constant total pressure and and the outlet as a mass flow rate. A mass flow at the inlet will have a constant velocity profile with a variable total pressure, which is not what you would have in your experiment.
-CycLone |
Dynamic Viscosity at transportproperties dictionary | NickolasPl | Main CFD Forum | 0 | June 2, 2011 14:06 |
Dynamic Viscosity of Acetylene or Critical Volume | JohnGane1987 | Main CFD Forum | 0 | March 30, 2010 06:01 |
User-defined turbulent viscosity - kinematic or dynamic? | tstorm | Main CFD Forum | 4 | January 29, 2010 11:08 |
User-defined turbulent viscosity - kinematic or dynamic? | tstorm | FLUENT | 0 | August 13, 2009 16:49 |
Help me with viscosity setup | Tony | CFX | 0 | January 24, 2005 10:32 |
