o grids in icem
Old   March 27, 2008, 09:22
Default o grids in icem
oli
I have a 2d hex mesh in icem that contains an o grid around the outside of a circle. I want to remove the circle from the geometry and hence the o grid from the mesh. If I just delete the block in the centre of the circle it does strange things to the surrounding blocks. I think I need to change the o grid blocks back to normal blocks but I can't find a simple way of doing so. Does anyone know how to do this?
Thanks,
Oli
Old   March 27, 2008, 09:47
Default Re: o grids in icem
myron
You'll want to merge vertices. Pick two of the vertices along the o-grid edge to remove that index - and it will go back to just h-grids. (You'll have to experiment on which vertex to pick first - but I think you first pick the vertex you want to remain.)
Old   March 27, 2008, 12:45
oli
Thanks. Got it to work with a combination of merging blocks and verticies
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 06:50
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 02:33
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
ICEM 10 mesh scale foe CFX Korsh Mik CFX 2 October 7, 2005 09:07
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
