finite plate --> Infinite plate???Infinite plate??? " border="0" /> finite plate --> Infinite plate??? |
March 26, 2008, 11:26 |
Dear friends,
I want to analyze "flow over a flat infinte plate". But we cannot model an infinte plate. So, what type of boundary condition should be applied in CFX at the outlet to create the situation of infinte plate?? (a 2-D problem is being solved). Thank you.. |
March 26, 2008, 12:20 |
Re: finite plate --> Infinite plate???
Simply set up an enclosure and extrude the flat plate profile all the way across. Set the walls to free slip and away you go. You can also set opposite walls to have mirrored meshes, you can of course simple make the enclosure one element thick.... hope that answers your question.
Steve |
infinite 2D perforated plate pressure drop | ACmate | Main CFD Forum | 0 | October 19, 2010 03:28 |
flow over an infinite flat plate | Vijay | CFX | 0 | April 7, 2008 05:01 |
heat transfer on dimpled plate | mech | FLUENT | 4 | February 6, 2007 15:15 |
Parallel Plate Rheometer vs Cone & Plate | beginner | Main CFD Forum | 0 | March 19, 2003 11:49 |
free convection between 2 infinite parallel plate | runny craven | Main CFD Forum | 2 | September 19, 2001 05:45 |
