April 7, 2008, 12:51 |
Dimension issues using CEL
hi,
I'm trying to write an expression for the input flow where the velocity varies with height as u=0.49ln(3631.82h) when I try this in ANSYS CFX I get an error saying that it expects the argument of the ln function to be dimensionless but obviuosly it's in m. any help would be appreciated Andy |
April 7, 2008, 20:51 |
Re: Dimension issues using CEL
make like this (where "Fluxrogerio" is the name of my variable in [W m^-2] and t is the time in [s] and more, A and B were created by myself just to become a dimensionless variable) :
Fluxrogerio (B*(19453.29701*(t/A)^3.07678)/(4.73947^3.07678+(t/A)^3.07678)) A 1.0 [s] B 1.0 [W m^-2] |
April 8, 2008, 03:50 |
Note that h / ( 1 [m] ) is dimensionless. Note that because the output of 0.49*ln(....) will be a dimensionless number, you will have to assign the correct units to the expression yourself to use it as a velocity in CFX. So... If h is measured in metres, and u in metres per second, then you should replace:
u=0.49ln(3631.82h) with 0.49 * ln(3631.82 * h / (1 [m]) ) * 1 [m s^-1] or, equivalently: 0.49 * ln(3631.82 [m^-1] * h) [m s^-1] There are several ways of typing it - I think it's up to you to choose the one that makes sense to you. ( NB: If you use other units of distance or speed you must alter the choice of units or add in conversion factors otherwise the answer will be wrong! ) HTH Andy2o |
April 8, 2008, 06:45 |
great, thanks for your help
April 8, 2008, 06:49 |
You´re welcome!
Angle variable under CEL. | Gloria Gaynor | CFX | 11 | November 26, 2012 06:29 |
the problem about dimension | bojiezhang | OpenFOAM | 2 | October 16, 2011 00:22 |
junction box routine and CEL function | bornspur | CFX | 2 | February 3, 2009 02:24 |
Rotate node via cel | Elian81 | CFX | 2 | September 25, 2007 05:31 |
dimension | lucy | FLUENT | 1 | July 13, 2001 12:42 |
