Mass residual becomes infinity
Old   April 19, 2008, 08:26
Default Mass residual becomes infinity
Debabrata
Hello
I am simulating a problem using upwind scheme. I have used a local time step factor of 0.9. If I do this the velocities (all u,v,w) and energy residuals come below the required 1e-5 and attains the steady value where as the RMS mass residual suddenly becomes infinity after a few iterations and continues to be like that.At this stage if I change the continuity equation from local time step factor of 0.9 to a physical time step or auto time step the RMS mass residual suddenly becomes zero and the problem becomes converged. In the beginning if I give a physical time step the problem diverges. Kindly let me know why this happens.
Thanks
Old   April 20, 2008, 18:26
Default Re: Mass residual becomes infinity
I suspect your simulation is not physically valid, or your mesh quality is poor or some other setup problem. This FAQ may also be of assistance http://www.cfd-online.com/Wiki/Ansys...gence_criteria
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
