FSI convergence problem
Old   April 13, 2008, 10:54
Default FSI convergence problem
YY
Hi guys,
I'm not sure if this would be the best place but I'm desperately in need of help.
Okay, so I'm modelling this FSI problem of a flow in a collapsible tube. Tube is circular with a constant external pressure acting on it. The pressure inside the tube is less than the external pressure applied causing the tube to deform inwards.Deformations are expected to be large and post-buckling effects are supposed to be captured. I'm modelling this in Workbench using the Ansys and CFX code coupling. This problem is a 2-way FSI.
So the problem is:
When I run the structural part alone, the net pressure acting on the solid is much higher than in the coupled solution which would mean than the deformation is larger but yet I could get the result to converged. However when I solve it together with the fluid part the structural part could not converged and there is always the error of elements turning inside out. Can anyone explain to me what's happening and how do I fix this. Thanks.
Regards, YY
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
Problem about FLUENT-MPCCI-ABAQUS FSI simulation! whpsoft FLUENT 0 May 24, 2006 10:22
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
