April 25, 2008, 09:51 |
volume fraction,mass fraction,bulk mass flow
"Hi! all friend I have a confusing problem when I try to set the value of "volume fraction" in the inlet condition fluid values tab for a gas-liquid two phase problem. If I give the value of volume fraction of different phase, what values should I give to the "Normal speed" of the two flow??are these values also apparent velocity or I should give a same velocity?? this problem confused me and I always give Mass flow rate for every flow.
by the way, when I select "Bulk Mass flow rate" in Boundary Details tab of inlet, I find the volume fraction in the fluid values tab means Mass fraction!(you can find this conclusion from the result file using CFX-POST).Is it true?? " Two questions above are cited from former messages which are just good for me.thanks for your reply! |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 10:30 |
Mass Flow Rate Error | jallison | FLUENT | 1 | May 16, 2011 16:22 |
Mass Flow Rate | student87 | CFX | 4 | January 2, 2010 04:45 |
mass flow in is not equal to mass flow out | skarp | CFX | 8 | August 19, 2007 01:55 |
