why the solver reject it? Anyone with experience? |
April 25, 2008, 20:20 |
I ran a very simple CFX application. But the solver could not work anyway. I am sure the licence is 100% okay. I first thought perhaps I used multi-block in the domain in my CGNS mesh. Then I try a Fluent mesh. It should be a single domain without internal interface this time. But the problem still appear. I have absolutely no idea about this trouble. Anything wrong with my setup or mesh? Thank you. The following is the solver messagesorry it might be a little bit long) +--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+ LIBRARY: MATERIAL: Air Ideal Gas Material Description = Air Ideal Gas (constant Cp) Material Group = Air Data,Calorically Perfect Ideal Gases Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1] Option = Value END EQUATION OF STATE: Molar Mass = 28.96 [kg kmol^-1] Option = Ideal Gas END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 2.61E-2 [W m^-1 K^-1] END END END END FLOW: SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END SIMULATION TYPE: Option = Steady State EXTERNAL SOLVER COUPLING: Option = None END END DOMAIN: Default Domain Modified Coord Frame = Coord 0 Domain Type = Fluid Fluids List = Air Ideal Gas Location = fluid BOUNDARY: Default Domain Modified Default Boundary Type = WALL Location = wall 4 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END WALL INFLUENCE ON FLOW: Option = No Slip END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: inlet Boundary Type = INLET Location = pressure inlet 6 BOUNDARY CONDITIONS: FLOW REGIME: Option = Supersonic END HEAT TRANSFER: Option = Static Temperature Static Temperature = 132.56 [K] END MASS AND MOMENTUM: Normal Speed = 568 [m s^-1] Option = Normal Speed and Pressure Relative Static Pressure = 10700 [Pa] END TURBULENCE: Option = Low Intensity and Eddy Viscosity Ratio END END END BOUNDARY: outlet Boundary Type = OUTLET Location = pressure outlet 5 BOUNDARY CONDITIONS: FLOW REGIME: Option = Supersonic END END END BOUNDARY: plenum_outlet Boundary Type = OUTLET Location = pressure outlet plenum BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Average Static Pressure Relative Pressure = 2741 [Pa] END PRESSURE AVERAGING: Option = Average Over Whole Outlet END END END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 0 [atm] END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Option = Total Energy END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = k epsilon END TURBULENT WALL FUNCTIONS: Option = Scalable END END END OUTPUT CONTROL: RESULTS: File Compression Level = Default Option = Standard END END SOLVER CONTROL: ADVECTION SCHEME: Option = Upwind END CONVERGENCE CONTROL: Length Scale Option = Conservative Maximum Number of Iterations = 50 Timescale Control = Auto Timescale Timescale Factor = 1.0 END CONVERGENCE CRITERIA: Residual Target = 1.E-4 Residual Type = RMS END DYNAMIC MODEL CONTROL: Global Dynamic Model Control = On END END END COMMAND FILE: Version = 11.0 Results Version = 11.0 END EXECUTION CONTROL: INTERPOLATOR STEP CONTROL: Runtime Priority = Standard EXECUTABLE SELECTION: Double Precision = Off END MEMORY CONTROL: Memory Allocation Factor = 1.0 END END PARALLEL HOST LIBRARY: HOST DEFINITION: host6170215 Remote Host Name = 617-0215 Host Architecture String = intel_xeon64.sse2_winnt5.1 Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX END END PARTITIONER STEP CONTROL: Multidomain Option = Independent Partitioning Runtime Priority = Standard EXECUTABLE SELECTION: Use Large Problem Partitioner = Off END MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARTITIONING TYPE: MeTiS Type = k-way Option = MeTiS Partition Size Rule = Automatic END END RUN DEFINITION: Definition File = C:/Team/cfx_fluent_bleed.def Interpolate Initial Values = Off Run Mode = Full END SOLVER STEP CONTROL: Runtime Priority = Standard EXECUTABLE SELECTION: Double Precision = Off END MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARALLEL ENVIRONMENT: Number of Processes = 1 Start Method = Serial END END END +--------------------------------------------------------------------+ | | | Solver | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | | | ANSYS CFX Solver 11.0 | | | | Version 2007.01.15-19.20 Mon Jan 15 19:24:21 GMTST 2007 | | | | Executable Attributes | | | | single-int32-32bit-novc6-optimised-supfort-noprof-nospag-lcomp | | | | Copyright 1996-2007 ANSYS Europe Ltd. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Job Information | +--------------------------------------------------------------------+ Run mode: serial run Host computer: 617-0215 Job started: Fri Apr 25 20:04:55 2008 No license for ANSYS CFX Solver (All Models) could be found. +--------------------------------------------------------------------+ | ERROR #001100247 has occurred in subroutine . | | Message: | | | | The solver is unable to continue because of licensing problems. | | | | A license for the following capability level could not be checked | | out: | | | | Basic Capability Solver | | | | Please carefully examine the error message output above and check | | that: | | | | 1) LM_LICENSE_FILE points to the correct license server | | | | 2) The ".flexlmrc" file points to the correct license server | | | | 3) The required capabililty exists on the license server | | | | 4) The license server is up and running. | | | | These problems can be checked using the ANSYS license manager. For| | further troubleshooting information please consult the section on | | setting up licensing in the ANSYS CFX installation manual. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. |
April 27, 2008, 13:39 |
Re: why the solver reject it? Anyone with experien
"I am sure the licence is 100% okay."
Sorry, but unfortunately CFX simply does not seem to agree with you! So what makes you sure? I don't think this has anything to do with your mesh or problem set-up - as a different error message would be given. And it is the basic solver it cannot find a license for... If CFX crashes during a run, or if there are network or computer problems, sometimes a license is not released correctly at the end of a run. If this happens, when you start the next run the license manager thinks the old run is still going and still using your license. You should run the ANSYS license manager, as the error message advises - I often find the easiest thing is to tell it to "Reread the license file" (but on a multiple user system you have to be careful!). Regards, andy |
April 27, 2008, 14:49 |
Thank you for your advice.
I search this forum and find that I am not the only one encountering "ERROR #001100247". I tested a very simple channel flow case, it's okay. But when I tried some other cases, the problem comes again. I have the experience running a multiblock turbine stator and rotor separately, they are all right. When I combined the two domains together and ran the coupled simulation, the "ERROR #001100247" arose. The domain interface setup is correct to my best knowledge. If a definition file worked once, it works every time. If it doesn't, it will never work. This is very tricky. I don't have any clue where is wrong. As I use CFX on workstation in the college computer lab, I can't access the license manager. Thanks. |
April 27, 2008, 18:12 |
OK... I was clearly wrong about this one. Apologies! I have been lucky enough never to see this problem myself (all my license errors have indeed been real license errors...). Good luck with sorting this out!
I hope someone else posts more helpful advice than I did! Best regards, Andy |
April 27, 2008, 20:03 |
The problem is definitely in the licensing. The error message clearly says so. I think what the problem is that you have a basic capability solver license, and that does not allow many physics such as multiple frames of reference (you use that for turbine simulations), multiphase, radiation and several other advanced physics options. There is also a node-limited solver option which some academic institutions use, you can only run small models on these licenses. Glenn Horrocks |
April 28, 2008, 12:47 |
I first did think we lack the full capability solver license when I did the coupled turbine simulation. But I have to give up this idea later when one of my coworker got the same work done in the lab. I got a copy of his .cfx and def. documents, and it really runs! I tried to find out what's the difference between his setup and mine. He used only one block for stator, one block for rotor, and the grid quality is not very good. he can applied multiphase flow model and erosion model in the simulation. So far, I have no hint and no luck stopping this evil error.
Our university obtain the CFX license from the donation agreement with ANSYS Inc. At least the full capacity solver is okay as I know. Whether it sets a limit on the maximum cell number, I never meet such warning message and have to check it out. Thanks. |
April 28, 2008, 14:08 |
I find it out now. There really exists a limit for the maximum number of cells that I can use in the software. I tried about 700k cells, it shows the license problem. when I cut the domain in half, it works this time.
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Error message | Pandu Sattvika | CFX | 0 | March 1, 2002 15:28 |
Could you comare StarCD with CFX 5?Help, please... | Suteh | CFX | 54 | November 7, 2001 20:12 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 16:25 |
