CFX- Turbo grid - Calculate the average Static Pre
Hi All I want to calculate the average static pressure for a case of axial flow turbine. Can u tell me how to do? I'm using CFX. Thanks
Dia |
Re: CFX- Turbo grid - Calculate the average Static
Hi Dia!
you have not described your problem,what u have done untill now?What u wants to do? Where u want this pressure? Still if u need avg static pressure on any boundary,u need to get it through Tools>function calculator in CFX-Post. Use function:Massflowavg,Variable as Pressure& location is your required Boundary. with best regards, Kumar. |
dear my problem is how to define the boundary condition well,now i set the mass flow rate for inlet and p-static at outlet(p-static=1atm),please what approperiate BC for axial flow water turbine kaplan if the net head is 40m and mass flow in about 116 meter cube/s.also how to present av static pressur is a presssure at required location denote to static pressure.or there is another method to calculate av static pressure
