a question about mass flow in multi-component flow |
May 12, 2008, 07:38 |
Hi, I am working with a multi-component flow now. My question is How can I compute the massflow for a single component of the multi-component fluid on a 2d boundary. I know in the cfx FAQ part an answer in perl has been given out, but I found it does work at all. An error likes this will be rise up: ERROR Syntax error detected in the expression assigned to 'expression'. Successfully read 25 characters:
Water Ideal Gas.massFlow@ then error detected at: Plane 1 Details - Syntax error: locator name may not follow variable name. Please give your advise. Thanks in advance! frank |
Display Modes | |
mass flow rate not conserved in turbomachine, interface defined wrong? | wildli | FLUENT | 3 | September 15, 2022 12:19 |
Mass flow rate through each cell | Babakjingo | Main CFD Forum | 0 | August 21, 2011 03:18 |
combustion problem | mcnair | CFX | 9 | March 22, 2011 14:06 |
different mass flow rates | michael | FLUENT | 4 | February 21, 2005 03:48 |
Determine mass flow rate along flow path | Atit Koonsrisuk | CFX | 2 | October 5, 2003 04:47 |
