Home > Forums > CFX
LImitation of CFX program in turbomachinery
Old   May 13, 2008, 04:42
Default LImitation of CFX program in turbomachinery
dia aisa
daer all please, i want to know what are the limitation of CFX software offered in ANSYS,my work focused in axial flow turbine ,but in all documentation i coud not found the limitation of the pachage
Old   May 13, 2008, 10:57
Default Re: LImitation of CFX program in turbomachinery
wayne
it is a really question.i want to know the different between ANSYS CFX and NUMECA FINE/TURBO for turbomachinery,but it is really quiet convient to do the pre and post.and i dont know if it can run pre and post in parallel way?
Old   May 13, 2008, 19:22
HekLeR
CFX can simulate an axial flow turbines.
There are three different models which allow you to *not* simulate the entire 360 degree machine.
Frozen Rotor and Stage can be used for steady state calculations with a change of pitch or shape. Frozen Rotor gives a ball park approximation at best, stage mixes out the flow going from one component to the next.
Transient Rotor Stator is used for transient and accounts for change of pitch and shape between components.
Old   May 19, 2008, 07:40
CFX beginner
There is a software named TurboGrid about the turbomachinery.
Old   May 20, 2008, 12:40
Farid
Hi HekLeR,
In my case, I made a circular domain and the center is not located at the origin. But, the domain is rotating around the origin though it should rotate around the center of the domain.
Can you please tell me the way to change the pivot of rotating domain when I am using the Transient Rotor stator Model?
Old   May 23, 2008, 21:41
HekLeR
I think I answered this already. See my other post. Use teh two point option or setup a coordinate frame which is not centered at 0,0,0. Select your custom coordinate frame axis x,y or z (depending which one lines up with the machine axis).
Old   May 23, 2008, 22:53
Farid
HekleR,
Thanks a lot.
Farid
Thread Tools
Trackbacks are On
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
Limitation of CFX -11 ! solving scalar and MRF Mohan R CFX 0 September 8, 2008 01:45
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
