why SST model???
Old   April 28, 2008, 12:14
Default why SST model???
vijay
Dear friends, I am solving external flow problem. Many people sugeested me to use SST model and interestingly, I got correct results with that. I tried K-w model which dint give proper results. I really dont know why SST gives better results and why not other models??? If someone asks why SST has been used in the case study, i dont have any answer.. Plz help me..
Thanks in advance...
Old   April 29, 2008, 07:41
Default Re: why SST model???
Dr Ali Seory
Hi Vijay Is an innovative Turbulence model (Menter F. R.). The model works by solving a turbulence/frequency - based model K-w at the wall and k-e in the bulk flow. A blending function ensure the smooth transition between the two models
Please check this link
http://www.idac.co.uk/products/downloads/10.0%20Innovative%20Turbulence%20Modeling,%20SST%20Mod el%20in%20ANSYS%20CFX.pdf
Dr. Ali Seory
Old   April 30, 2008, 10:52
Felix
Try to put your hand on Menter's article on the SST (I know there are at least 2 of them). You can also have good info in books such as Wilcox or Versteeg & Malalasekera.
The idea behind the SST model is to take advantage of the good sides of the k-w model without having to deal with its sensitivity to the w value imposed more or less arbitrarily on the boundaries.
Other models could be interesting to test for your application: k-epsilon, Spalart-Almaras, etc...
Old   May 22, 2008, 03:05
wayne
Hi Felix i can not find the paper Menter.F.R "Zonal two eqution k-w turbulence models for aero dynamic flow"AIAA paper 93-2906,1993.for it can not be found in website of AIAA.the some of other paper by Menter.F.R quoted that one. there is more detail in that paper. can you help me to get this paper?
SST turbulence model PCFD CFX 56 June 20, 2017 15:45
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
Convergence issue in SST for Porous model Raj CFX 0 May 2, 2008 02:43
SST model and boundary layers Rodrigo Basniak CFX 7 March 27, 2008 14:19
Stalling residuals in kw SST turbulence model jorllam CFX 3 February 13, 2007 15:51
