Catalogue error
Old   May 22, 2008, 09:06
Default Catalogue error
sudhakar
I am currently doing conjugate heat transfer analysis with a mesh size of 4.3 million elements,while trying to run this model into parallel computing with 4 processors we are facing an error stating INCREASE THE CATOLOGUE SIZE .
Old   May 23, 2008, 05:27
Default Re: Catalogue error
Bela Kiss
Dear Sudhakar,
You should edit your definition file in the Solver. Solver - Edit definition file - (choose your def file) - flow - solver control -( when you are here you can choose the "edit" - add parameter) - in the pop up window you will see the "catalogue size multiplier") - you can type here for example 1.2
Best regards
Bela
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
