May 26, 2008, 22:02 |
Is it possible to monitor residuals...
Hi All,
Is it possible to monitor residuals of specific areas in a region while a solution is being run? Or is it only possible to monitor the residuals of entire regions? Thanks, Tim. |
May 26, 2008, 23:48 |
Re: Is it possible to monitor residuals...
Tim,
Residuals of different domains can be ploted in the monitor respectively. You can select "Monitor Properties" from the right-click menu on the monitor screen, and then toggle on or off variable residuals you want. Maybe you need to define the specific area as a domain. But I am not sure because I have not found the way to display arbitrary areas' residuals. May this help. R.Y |
