creating a Sub-domain
Old   June 2, 2008, 05:04
Default creating a Sub-domain
MAB
Any idea of ,how to create a subdomain of half the size of the whole rectangular domain. I want to do this to inflate the interface of the domain to get finer mesh at the solid-gas interface. thanks in advance.
Old   June 2, 2008, 09:07
Default Re: creating a Sub-domain
CycLone
Hi MAB,
Before explaining how to do this, I suggest you simply apply an appropriate mesh control and inflate the mesh from the desired surface in the Meshing application. You should have inflation there anyhow, as this is a wall boundary.
In DesignModeler: If you want to get a volume next to your surface, you can try creating a Named Selection on the surface of interest and extruding or revolving this surface to slice out the volume you need. Alternatively, you may be able to create a thin body around the surface. It's really too difficult to describe the process in detail here, so I suggest trying a few things in DM and reviewing the on-line documentation.
-CycLone
Old   June 3, 2008, 07:08
Mehul
HI MAB,
This can be done by making two separate geometries and combined them into CFX Pre. In Pre you can define the interface between them.
- Mehul
Creating arbitrary surfaces in meshed domain suh OpenFOAM 7 August 20, 2019 13:27
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Creating 2D Multi Domain dark_x ANSYS 1 September 5, 2011 13:54
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
