Monitor point values in a steady state simulation |
July 4, 2008, 18:04 |
A steady state simulation with Blend factor =0.9 has reached the situation where RMS residual levels are 10^-6 and global imbalances are near 1% or 2%.
BUT the monitor point values such as Volume fraction at the outlets are still changing (slightly) with iterations. Should I consider the simulation reached steady state? In short, my question is as follows: "Should the monitor point values NOT change with iterations in steady state if the steady state has been obtained?" Thanks, Kushagra |
July 6, 2008, 18:49 |
Re: Monitor point values in a steady state simulat
I would say that you want low residuals, low imbalance, and small fluctuations in any monitor points to consider your solution to be converged. The fluctuations in a monitor point will give you some indication as to the accuracy of the final solution.
If you monitor point is fluctuating, maybe you have a condition that is unsteady, and you may want to consider running it transient to get better accuracy or model the flow properly. |
July 13, 2008, 20:03 |
I am simulating a case in a steady state and the temperature and the velocity are changing. You can decrease the target error to see if the results are reaching the steady state
Adding heat source to chtMultiRegionFoam | maddalena | OpenFOAM Programming & Development | 61 | February 17, 2018 08:33 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
exhaust manifold -steady state simulation | turbotel | CFX | 0 | November 30, 2010 06:09 |
steady state simulation | manoj | FLUENT | 1 | March 20, 2004 07:15 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
