ICEM Meshing error
Hi all,
I used the "2D planar" blocking method to mesh my 2D rectangular pipe with a single indentation. When I turned on the "pre mesh" option, everything looked ok; there were quad elements nicely setup. When I clicked "compute mesh" and selected "hexa dominant", ICEM 11 gave the following error: error orienting normals, perhaps there is more than one region error in output_region_boundaries Hex Dominant meshing failed Just wondering how this could happen when everything looked ok in "pre mesh"? How would I fix this problem? Thanks! CC |
Re: ICEM Meshing error
You simply need to convert the pre-mesh to an unstructured mesh (this can then be written to your solver). If you right-click on Pre-Mesh you should see the option 'Convert to Unstructured Mesh'.
The hexa dominant meshing is for filling a volume mesh based on an existing surface mesh. |
