June 6, 2008, 00:45 |
ICEM Meshing error
Hi all,
I used the "2D planar" blocking method to mesh my 2D rectangular pipe with a single indentation. When I turned on the "pre mesh" option, everything looked ok; there were quad elements nicely setup. When I clicked "compute mesh" and selected "hexa dominant", ICEM 11 gave the following error: error orienting normals, perhaps there is more than one region error in output_region_boundaries Hex Dominant meshing failed Just wondering how this could happen when everything looked ok in "pre mesh"? How would I fix this problem? Thanks! CC |
June 6, 2008, 10:59 |
Re: ICEM Meshing error
You simply need to convert the pre-mesh to an unstructured mesh (this can then be written to your solver). If you right-click on Pre-Mesh you should see the option 'Convert to Unstructured Mesh'.
The hexa dominant meshing is for filling a volume mesh based on an existing surface mesh. |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
