how to creat a surface with thickness
Old   June 12, 2008, 03:28
Default how to creat a surface with thickness
Marvin
hi,I need to creat a surface of 5 mm thickness during building geo.I only find some information about this in repair geo>adjust varying thickness.Could someone give some hint?thanks
Old   June 14, 2008, 01:19
Default Re: how to creat a surface with thickness
Marvin
I'm sorry for my poor english.My question is not very clear.For example,if I want to creat a square surface 5 mm deep,then what I shoud do is build it as a square entity. Am I right? thanks
Old   June 14, 2008, 07:01
Rogerio Fernandes Brito
U can make this on Solid Works and export to ICEM CFD as step file or parasolid file! do you want to analyze the conducting heat transfer at cubic walls? Tell us about the dimensions of your geometry!
Old   June 14, 2008, 22:58
Marvin
you mean a surface with thickness can't be created during ICEM CFD?thanks,Rogerio and no heat transfer,there are lots of ostioles on the cube 5mm thick. Air or water can flow through them.I only want to analyze the flow identity such as velocity,pressure... however,2D mesh can't be import into cfx.So...
Old   June 24, 2008, 15:17
Jo
So, let me make sure that you like to generate 2D geometry..right?
then the thickness does not matter. (you can have any thickness you like to have)
But Make sure CFX can only import volume element.
so generate a thin volume, and when you mech the volume, make sure you have only one layer of volume element.
After that apply symmetric boundary conditions for both walls.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
