June 16, 2008, 06:53 |
Batch
Hi I have 10 different cad models where there is one parameter that is varied. I would like to mesh this cad file and then put on BC, where I want the BC to change 10 times for each meshfile,. Pressure at inlet to go from 0 to 10 bar. Then I want to solve it and read out the massflow at the outlet. This should be 100 runs and therefore I would like to do this in a batch job, how do I do that. Each file works fine now, so now I am trying to find out how that one geometry parameter effects the result.
Cheers Kim |
June 16, 2008, 21:47 |
Re: Batch
hi,
Automating the pressure from 0-10 bar is easy, use CCL and a script (Linux) or batch (Windows) file to run the series of runs. Scripting the geometry changes is trickier but can be done. Whether it is quicker just to generate the geometry files yourself and run the batch file will depend on what you are trying to do. Glenn Horrocks |
June 17, 2008, 10:54 |
Re: Batch
Well easy and easy...
What I did was to make several ccl files, where I changed them manually, see comment in text. DOMAIN: Default Domain Coord Frame = Coord 0 Domain Type = Fluid Fluids List = Molasse Location = B4 BOUNDARY: Inlet Boundary Type = INLET Location = F319.4 BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Total Pressure Relative Pressure = 5 [bar] <----- changing this value in each file.. 11 files 0 - 10 bar with 1 bar step. END END END I would also like to post process them somehow, below I made a small perl scrip that gets the value I am interested in, but how do I extend my code to take all the result files in a given directory and save the result in 11 different files? This is the command I am currently sending to the solver: cfx5solve -def ..\molassenicer_mesh.def -ccl ..\DefFiles\0bar.ccl cfx5solve -def ..\molassenicer_mesh.def -ccl ..\DefFiles\1bar.ccl -initial 0bar_001.res cfx5solve -def ..\molassenicer_mesh.def -ccl ..\DefFiles\2bar.ccl -initial 1bar_001.res the problem is that name of result file is incorrect, how can I force the result file to have a given name? Cheers Kim |
June 19, 2008, 02:52 |
Re: Batch
As I understood from your message, You are looking for 10 different values of pressure BC on same surface and individual result file for them.
I think you should create 10 different .def files . Make Batch executables and simply run batch file from Batch command of CFX . It will generate individual res files. |
June 19, 2008, 02:56 |
Re: Batch
I made some matlab script that modifies the ccl files and then I run it with the same def file. This works fine. But I would imagine that there should be an easier way than making regex for the ccl file to change the pressure at the BC.
June 19, 2008, 11:05 |
Re: Batch
How can I run my .pre files from the commando line? My script works nicely when I: file->new simulation Session->Play file Then I select the file...
Shouldn't this be the same as cfx5pre -batch file But this always returns file handle -1 What does this mean? Cheers Kim |
Run Multiple Files in Batch | nickninevah | STAR-CCM+ | 6 | October 12, 2017 06:17 |
to run a replayfile in batch mode from UNIX | froztbear | ANSYS Meshing & Geometry | 4 | May 13, 2014 08:00 |
Windows XP Batch file help needed | DL123 | Main CFD Forum | 2 | July 3, 2009 08:53 |
Running Job in Batch mode (EFD) | Nick Sessions | FloEFD, FloWorks & FloTHERM | 0 | April 16, 2008 16:44 |
batch run | N.R. | CFX | 1 | June 17, 2007 22:44 |
