Defining a variable Viscosity ??
Any idea of how to define viscosity of water to be a funcions of x coordinate? I want to increase the viscosity after a specified distance in horizontal direction. Any suggestion 'll be appreciated. Thanking in advance. MAB
Re: Defining a variable Viscosity ??
do you want to know how to make the expression or what expression to use?
For example: dynamic viscosity as a function of x coordinate times 2. ownvisc(X) A = 1.0 [Pa s] B = 1.0 [m] ownvisc=(A*(2*(X/B))) Make a CEL expression and edit this material on what you are working in! |
Thanks Rogerio F.B. i will try this. what i exactly want is to increase the viscosity of water by 10 times after say x=20m where as total length along x-axis is 30m. i have tried it usin step function as step((x-20)/1m)*10*viscwater + actual viscosity of water but the solver didn't run ..each time it gave an error. any suggestion
The solver will not allow the viscosity to change based on spatial coordinates make sense physically.
What are you physically trying to model? Why is the water viscosity changing at all? -CycLone |
Hi CycLone, I am modelling water waves on free surface. neer outlet i want to increase the viscosity of water so that the waves gets damped before approching the outlet, i want to do this to avoid refelection. (it has been easily done in starccm+) any further suggestion?(
step((x/1[m]-20)*10*viscwater+actual visosity of water
