Mesh problems for keel
Im having troubles with getting a good mesh for the leading and trailing edge of a keel. Im using the Tetra mesh with 3 prism layers and decreased the tetra height as far as I can go with current computer. Any ideas? Here's link to a pic of the problem:
http://img213.imageshack.us/my.php?image=keelfk8.jpg Thanks! |
Re: Mesh problems for keel
The trailing edge seems to be quite sharp. There are two issues here. 1 - You'll probably want to use 'thin cuts' to keep the two sides of the keel separated and avoid the 'jagged' trailing edge mesh. Then you can use a larger mesh size and keep the two sides separate. (See the help system or contact your support rep for details on using thin cuts.) 2 - The prisms might be messy due to the two normals at the trailing edge being almost 180-deg apart.
I would make the geometry two blocks split along the symmetry plane. In my experience thin cuts is variable, sometimes works, sometimes doesn't. Glenn Horrocks |
