-   -   CFX 11, post (http://www.cfd-online.com/Forums/cfx/26002-cfx-11-post.html)
Anant June 23, 2008 08:25
CFX 11, post
Hello All,
I have a little problem with the CFX post,
I am trying to use post and wrote the expressions to obtain the values(at some point in the model) in Table viewer (tab next to 3d viewer).
since I will need the same expressions for a set of simulations , I woulndn't want to rewrite the expressions all over again, so I saved the .cst file (in table viever tab) so that I could read the expressions in table viewer every time and get the results instantly.
But now I am not able to retrive the expressions when I read them through 'table viewer' tab
everything else works fine except reading the ' .cst' file in table viewer. surprisingly it doesnot give any error messege.
Is this a Bug in CFX 11...?
please reply
thanking you Anant
hsr June 24, 2008 11:03
Re: CFX 11, post
Hi Anant,
after you load the .cst file, the table object including your expressions is not automatically loaded into the table viewer. You have to load it by double-clicking on the entry of the loaded table in the (usually left aligned) 'object tree' frame in CFX Post in branch 'Report'.
Hope it works for you, too (tested it with CFX 11 SP1)
