Axial Thrust in a Radial Turbine
How do we calculate axial thrust in a radial turbine in cfx-post?
I have a case of Francis Turbine in which I want to calculate Axial Thrust along the direction of rotation. Regards, Amit Roghs |
how can i get performace of axial turbine in CFX-p
dear all plaese how can i get performance of axial turbine in CFX-post. i used macro calculater in cfx-post. but the results is not write.is there any different method to calculate the eff , power, torqou or any variable from cfx-post
Re: how can i get performace of axial turbine in C
Input Power = ((Total Pressure in Stn Frame at Inlet)-(Total Pressure in Stn Frame at Outlet))*Discharge
Output Power = Torque on Runner Blades *2*pi*N/60 Efficiency = Output Power/Input Power Each of the above terms in each power are need to be calculated using Function Calculator. Torque is also available in the function library. In the option go to massflowavgabs and then calculate Total Pressure in Stn Frame for inlet as well as outlet. Regards Amit Roghs |
Hi
Someone Know how can I mesh in gambit a profile of a gas turbine please I have to grid a profile like this image:( http://co103w.col103.mail.live.com/a...CCAF4817F4F0|| |
