CFX: multiple domain error
Old   July 1, 2008, 10:08
Default CFX: multiple domain error
Xueguan Song
hello, everyone
I'm using CFX to calculate the 'Catalytic Converter', the problem is very easy, and most settings are default. However, after two steps the error always happen, and it's my first time to encount this problem. so Please, if anybody knows, Please help, thanks in advance!
the following is the error:
************************************************** ********** +--------------------------------------------------------------+ *** INSUFFICIENT CATALOGUE SIZE ***
ACTION REQUIRED : Increase the file catalogue size. If the situation persists please contact the CFX Customer Helpline giving the following details:- Current catalogue size : 67154 +-------------------------------------------------------+
Details of error: Error detected by routine MAKLNK COLDNM = /FLOW/MESH/TOPOL/ZN4 CNEWNM = /FLOW/GETVAR/MESHTOPO_ZONE_DPA CRESLT = FCAT
Current Directory : /FLOW/SOLUTION/TSTEP2/CLOOP1/ZN4/IELG73/VERTEX
+-------------------------------------------------------+ An error has occurred in cfx5solve: The ANSYS CFX solver exited with return code 1. No results file has been created. +-------------------------------------------------------+
Old   July 1, 2008, 23:01
Default Re: CFX: multiple domain error
CFDUSERIN
Hello
you search the following keyword in the CFX forum
you will get the solution
regards UERIN
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
