How to extract data from a completed transient run
I have completed a transient simulation without everything recorded as transient results. How can I obtain those useful data without completely re-run the simulations please? Or alternatively, could I add more Monitor Points at a finished run?
Say, in this case, I have only recorded Trasient Result: Velocity in every timestep, and Trasient Result: Static Pressure in every 3 timestep, how can I monitor the massFlow and Pressure at the outlet? (Without completely re-run the simulation)( or just partially re-run the simulation) Thanx a lot. |
Re: How to extract data from a completed transient
Vince, I don't know if this will work, but try adding the transient information you want in Pre and run a few time steps like that. I've never tried it, interested to know how you get on. Sally.
Hi Sally, thanx for your post. I understand this is the way to do it. However, this is like setting up a new simulation. I'm seeking a way to run a simulation on the based of the old result, or calculated those parameters based on the existing. Regards, Vince.
