install the openfoam
HI every one can you tell me from where can I install the openfoam.exe please
Re: install the openfoam
Hi Aya
Are you planning to install OpenFOAM on your PC. If you know how linux and c++ works, you can download binary files from openFoam web site and then untar them in right order. www.openfoam.org If you dont know linux much, easier and infact route would be be to along with caelinux. www.caelinux.com Regards |
Re: underGroundMan
thank you underGroundMan for answer, but I can not find the staps of installation
Re: underGroundMan
Are you installing caelinux? In that case you will burn caelinux ISO image on dvd first and create a bootable dvd. If you want to install caelinux on your pc then, all the instructions are available in caelinux documentation section.
If you already have a linux platform and you just want to install OpenFOAM, then you need to download the binary files from openfoam's web site and untar them in right order. Regards |
Re: underGroundMan
What is the difference between lunix and caelinux and what is the platform that simplify the work Thank you in advance
