June 23, 2008, 19:31 |
icem hexa mesh beginner
hello, i am beginner in ICEM CFD.i have to simulate a flow over a NACA0015 airfoil.i have the final blocking.but when computing with pre-mesh,all geometry(the external flow+internal surface of airfoil)will be meshed.then i have to avoid the internal airfoil mesh. please,i will be grateful to receive any idea. thanks.
June 24, 2008, 02:12 |
Re: icem hexa mesh beginner
You have to go to edit mesh option , apply flood field , here you can save the mesh in the region you want.
July 9, 2008, 07:18 |
thanks pratik mehta. but what i have got in "edit mesh :flood field is concerning tetra mesh only.and i dont get it for the hexa mesh. but i have done it easly with an other manner.whith deleting block.
July 23, 2008, 04:26 |
use create part option from parts.Name the part and add the airfoil block to it.While doing pre-mesh switch off airfoil part.This will solve the problem.Just check.
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
icem hexa mesh beginner | icem beginner | Main CFD Forum | 3 | July 9, 2008 07:08 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
CFX4 mesh from ICEM HEXA | David | CFX | 2 | June 27, 2005 18:35 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 06:46 |
