Icem "imprint face" command
Old   July 24, 2008, 12:49
Default Icem "imprint face" command
Lindner
Hi, i want to know if there is a command like "imprint faces" from ansys workbench on icem. I generated a mesh and exported to CFX but my Inlet doest appear. My inlet is a part of the wall
icem -> http://img146.imageshack.us/my.php?image=inletfo1.jpg
cfx pre -> http://img504.imageshack.us/my.php?image=inlet2dm1.jpg
as you can see, the inlet doesnt appear, just saida (outlet) simetria (simmetry) piso (heated floor) and paredes (adiabatic wall)
thank you in advance
Old   July 24, 2008, 15:28
Default Re: Icem "imprint face" command
Lindner
I figured out my problem. I was using 3 blocks, now im using 4 block (the new one in on the inlet).
Problem solved
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
WARNING: non-positive face area exist. Alan Main CFD Forum 4 August 17, 2006 07:33
