-   -   2D periodic problem (http://www.cfd-online.com/Forums/cfx/26207-2d-periodic-problem.html)
Markus August 4, 2008 14:43
2D periodic problem
Hey all, I need some help.
I am modelling a 2D turbo machinery passage using ICEM. I have set a translational periodicity and applied it to the blocking... then applied all edge and point associations and checked the periodicty of the resulting grid. It says no problems found and I have rechecked often. Now I export the mesh into Fluent V6 but when I load the msh, Fluent gives me the following error:
Building...
grid,
Warning: Inappropriate zone type (periodic) for one-sided face zone 15.
Changing to wall. Warning: Inappropriate zone type (periodic) for one-sided face zone 16.
Changing to wall. Error: FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
If I just define the periodic curves/boundaries as walls, Fluent loads just fine, but without the option of making those 2 periodic.
I cannot seem to find out what I'm doing wrong... Maybe someone might have more insight into the precedure.
Thanks, Markus
