-   -   FSI using CT-images - need more geometries!? (http://www.cfd-online.com/Forums/cfx/26220-fsi-using-ct-images-need-more-geometries.html)
Liza August 6, 2008 08:48
Hi all,
I have a geometry from CT-images at four different times which I want to perform a FSI-simulation on. It's 0.25 s between each geometry, and I want to get more geometries to be able to do a more realistic FSI. I have looked into tutorial 20 (check valve with 20 meshes) and it seems to suit me, the only thing I need now is the meshes.
So my problem is that I only have 4 geometries and I need 100. Is there an easy way to "interpolate" and save geometries in CFX or do I need to use an external CAD program?
Or should I do it in some other way?
Cheers Liza
Jorn August 6, 2008 09:50
Re: FSI using CT-images - need more geometries!?
I know people use the software Mimics to generate meshes from CT images for use in Ansys/CFX. I don't know if it can interpolate though.
Rogerio Fernandes Brito August 6, 2008 12:19
Please, Mr. Liza, tell us about this scheme. I didnīt understand very much this methodology. Thanks
Liza August 7, 2008 02:14
First of all, it's MISS and not MR... ;)
So, say that I have a geometery at time = 0 and one geometry at time = 0.25, 0.75, and 1.00. To be able to perform a FSI in the same way as in tutorial 20, I need meshes at time = 0.01, 0.02, 0.03 and so on, if my time step is going to be 0.01.
So I was wondering if CFX has any capabilities to perform a interpolation between time = 0 and 0.25 to get the intermediate geometries, or if I have to use another CAD program.
Or (preferably?) if I can solve my problem in another way?
Cheers Liza
Rogerio Fernandes Brito August 7, 2008 07:37
Did your geometry change with the time?
Liza August 7, 2008 08:31
Yes of course - thats why Im trying to do a one-way FSI...
Rogerio Fernandes Brito August 7, 2008 21:32
Thanks lady Lisa!
Liza August 8, 2008 02:47
brunoc August 8, 2008 15:42
Sorry, Post won't do that for you. You'll have to do it externally.
Liza August 11, 2008 06:14
I was thinking that it might be possible in cfx pre? Or doing something with junction box routines and write new intermediate meshes?
brunoc August 11, 2008 18:04
No, Pre won't interpolate geometries. You can probably do it with the meshing API. It is still done outside CFX, though.
Liza August 12, 2008 09:33
Ok, I'll give it a try. Thanks for your help.
