can I use static enthalpy gradient to describe dT
Old   August 6, 2008, 23:01
Default can I use static enthalpy gradient to describe dT
Jay
Hi, In a pipe fluid flow, fully developed. After I get the temperature field and velocity field (T, U),How can I get the corresponding temperature gradient in x,r direcion, for velocity, it seems I can use the velocity gradient in x,y,z direction. But there is no temperature gradient in the CFX-post. Cause we can easily get the static enthalpy gradient, can I use the the static enthalpy gradient to describe the temperature gradient, h=Cp*T -->dh/dx=Cp*dT/dx??
Thanks
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
dp/dt, udp/dx terms in static enthalpy equation CFDtoy Main CFD Forum 0 April 13, 2007 10:41
meaning static enthalpy and total enthalpy mspark Siemens 1 April 1, 2004 06:20
