August 19, 2008, 04:07 |
How to call a subrutine writen with Fortran
I'm triying to do Tutorial 17 and I'm having a lot of problems to call a subrutine that apears into the tutorial. I'm using Compaq Visual Fortran 6.6.0 as a compiler and I don't really know if it can be used with Ansys V11. I dont't know if that's the problem or rather I'm using incorrectly the cfx5mkext command. If someone could help me I'd really appreciate.
August 19, 2008, 05:12 |
Re: How to call a subrutine writen with Fortran *NM*
August 19, 2008, 08:33 |
Hi Lana
I have just installed compaq visual 6.1, standard edition. I am also trying to compile a subroutine in tutorial 9, but it does not seem to be working. What platform are you working on? Regards |
August 19, 2008, 17:38 |
You have to change the cfx5mkext.ccl file to use Compaq Visual Fortran on v11. Check the documentation.
August 20, 2008, 05:41 |
As Brunoc said, you have to change the cfx5mkext.ccl file in order to use Compaq Visual Fortran (it is explained in ANSYS help when you search for cfx5mkext) however, I'm using Compaq Visual Fortran6.6.0, using ANSYS V11, I'm not sure if it'll work with 6.1. If anyone is trying to solve tutoril 17, instead of using the recomended line in the command editor:
! system ("cfx5mkext TStat_Control.F") < 1 or die "cfx5mkext failed"; try using this instead (in my case, it worked): ! { ! local $SIG{CHLD}='DEFAULT'; ! ! my $rv=system ("cfx5mkext TStat_Control.F"); ! ! if ($rv == -1) { ! die "Error getting return value from cfx5mkext: $!"; ! } elsif ($rv != 0) { ! die "Error $rv running cfx5mkext. See terminal window for details: $!"; ! } ! } ! use Cwd; ! my $here=getcwd(); |
Display Modes | |
Call Fortran program from OpenFoam | tsjb00 | OpenFOAM Running, Solving & CFD | 6 | April 22, 2013 15:26 |
How to call FLUENT in my Fortran source? | Sandia | FLUENT | 2 | December 1, 2012 15:33 |
How to call FORTRAN files as UDF? | Ehsan-F | Fluent UDF and Scheme Programming | 6 | September 11, 2012 11:03 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
2D CFD code using SIMPLE algorithm | bfan | Main CFD Forum | 3 | June 22, 2002 22:01 |
