August 21, 2008, 11:15 |
error
hi all i got one error,what can i do this
ERROR #002100048 has occurred in subroutine SU_BNEXT. | | Message: | | All vertices for a fluid domain lie on boundaries. This is | | considered to be a fatal error because control volume gradients | | cannot be calculated, leading to serious discretization error. | | | | A common cause for this error is a mesh which is only one | | element thick, without symmetry or 1:1 periodicity on the lateral | | boundaries. If you have this situation, and the domain is | | two-dimensional, please change the lateral boundary conditions | | to symmetry or 1:1 periodicity. Alternatively, for | | three-dimensional simulations, please ensure that your mesh | | has at least two elements across. | | | | Execution is terminating. This error message can be bypassed by | | setting the expert parameter 'boundary vertex check = f', but | | be aware that doing so may lead to sigificant solution error. | +--------------------------------------------------------------------+ |
August 21, 2008, 11:25 |
Re: error
are you trying to model it as 2D or 3D ? If 2D then use extruded 2D option for mesh and define extruded periodic pairs.
August 21, 2008, 11:31 |
Re: error
3D model
August 22, 2008, 01:25 |
Re: error
In that case you have a meshing error. As the message says it appears all the nodes lie on the boundaries with no internal nodes. Glenn Horrocks |
August 22, 2008, 01:59 |
Re: error
hi Glenn Horrocks, ok, i created in ICEM CFD,how to modify in that situation i taken elements:3lacs TETRA MESH ONLY THANKYOU
Display Modes | |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
