Home > Forums > CFX
error
Old   August 21, 2008, 10:15
Default error
sivaramakrishnaiah
hi all i got one error,what can i do this
ERROR #002100048 has occurred in subroutine SU_BNEXT. | | Message: | | All vertices for a fluid domain lie on boundaries. This is | | considered to be a fatal error because control volume gradients | | cannot be calculated, leading to serious discretization error. | | | | A common cause for this error is a mesh which is only one | | element thick, without symmetry or 1:1 periodicity on the lateral | | boundaries. If you have this situation, and the domain is | | two-dimensional, please change the lateral boundary conditions | | to symmetry or 1:1 periodicity. Alternatively, for | | three-dimensional simulations, please ensure that your mesh | | has at least two elements across. | | | | Execution is terminating. This error message can be bypassed by | | setting the expert parameter 'boundary vertex check = f', but | | be aware that doing so may lead to sigificant solution error. | +--------------------------------------------------------------------+
Old   August 21, 2008, 10:25
Default Re: error
MAB
are you trying to model it as 2D or 3D ? If 2D then use extruded 2D option for mesh and define extruded periodic pairs.
Old   August 21, 2008, 10:31
Default Re: error
sivaramakrishnaiah
3D model
Old   August 22, 2008, 00:25
Default Re: error
In that case you have a meshing error. As the message says it appears all the nodes lie on the boundaries with no internal nodes.
Old   August 22, 2008, 00:59
Default Re: error
sivaramakrishnaiah
hi Glenn Horrocks, ok, i created in ICEM CFD,how to modify in that situation i taken elements:3lacs TETRA MESH ONLY THANKYOU
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
