Home > Forums > CFX
why downstream height is defined?
Old   August 28, 2008, 06:15
Default why downstream height is defined?
NITIN DEWANGAN
hi, can anybody tell why we are using downstream height downH in the tutorial problem no 7 of flow over free surface bump? i am confused, what will happen if we remove that expression.
is there any effect on the outflow side?
Old   August 28, 2008, 18:25
Default Re: why downstream height is defined?
MAB
For an outlet boundary condition , in CFX , you have to specify volume fractions for each fluid . You can avoid this specification by changing it to an opening with a sepcified pressure. or in outlet change volume fractions to zero gradient.
Old   August 28, 2008, 23:37
NITIN DEWANGAN
thank MAB,
this is correct, ifwe take some pressure, the result would be same , but in my case, there is a twist in the problem: i am continuing this problem by looking hydraulic jump after and over the bump.
i simply take static pressure value at outlet, the results differ from the previous cases when i used downstream height.
i just want to know, what is the fluid mechanics fundamental involve with this outflow boundary condition?
thanks.
NITIN DEWANGAN
thank MAB,
this is correct, if we take some pressure, the result would be same , but in my case, there is a twist in the problem: i am continuing this problem by looking hydraulic jump after and over the bump.
thanks.
Old   August 29, 2008, 02:41
NITIN DEWANGAN
with this post, i want to ask one more thing is that.
if downstream height is defined, what should be its height? how it is considered??
Old   August 29, 2008, 07:28
MAB
I think they used a lower height at downstream as compared to the one at inflow boudary. The reason is that water level would decrease gradually as the water goes out of the tank . so the downH is the rough estimate of this lower level.
You can even keep the level same as at inflow boundary.
Thread Tools
Trackbacks are On
[ICEM] How can I define different zones in ICEM? llrr ANSYS Meshing & Geometry 13 August 4, 2014 20:04
Specifying the height of the first cell of a block using simpleGrading bigbang OpenFOAM Native Meshers: blockMesh 1 June 16, 2011 13:52
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 05:06
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
